You can only use this procedure on a switch with boundary-node abilities.Perform this procedure to specify the IS-IS area where Auto-sense creates a specific ExtremeCloud SD-WAN-learned tunnel. This configuration overrides a global area configuration for all learned tunnels.
- In the navigation pane, expand
- Select AutoSense.
- Select the Sd-Wan Multi-Area tab.
- Select Insert.
- In Ip, type the destination IP address.
- In Area, select home or remote.
- Select Insert.
Sd-Wan Multi-Area Field Descriptions
Use the data in the following table to use the Sd-Wan Multi-Area tab.
Name | Description |
Ip |
Displays the destination IP address for an ExtremeCloud SD-WAN-learned tunnel. |
Area |
Specifies the IS-IS area where Auto-sense creates the tunnel. By default, Auto-sense creates SD-WAN logical interfaces in the home area. |
